- Jul 28, 2007
so i have been looking up all the info i can for the past two days on WC systems, becuase im buying a prebuilt system from a from a guy. and the info i have gotten has been all across the board.
ok from what he said im inferring that i have to buy lots of distilled water and PTnuke for after cleaning
for cleaning [i want to make sure this is right]
as a side note, if i wanted to add a GPU block in the future what would i have to upgrade?
also i was wondering, should i lap a WC system?
* ThermoChill PA 160 Radiator
* Acrylic Bay Reservoir
* D-tek DB-1 Pump
* D-tek FuZion CPU WaterBlock
* ClearFlex60 1/2" ID tubing
* Primochill PC Ice Steel Blue with UV Dye added
NOTE: Imho, it is time to drain, flush and re-fill the loop. Were it me, I would disassemble the entire loop and thoroughly clean all the components.
- drain the loop
- pump should use warm vinegar and distilled water to flush it and rinse with distilled water again
- for the radiator i put in very warm distilled water and shake it around and rinse that with more distilled water
