- Feb 9, 2002
Hows the water cooling market pricing wise? more to the point has the pricing been lowering or pretty much stable for long term?
Reason i'm asking is i expect my next gpu I buy will be a water block mounted gpu and I'm debating adding a 3rd rad now to compensate for it later if the market is rather stable.
This will do two things.
It will let me know if my current 2 rads "1x120mm RX XSPC and 2x120mm RX XSPC rads" are holding strong with my cpu/board heatsink's and the overclocks I have currently.
And also allow me to upgrade later to a gpu block with only having to buy the block.
I'm thinking I will go external with a rad and stand and just run modded fan wires out the back of case.
probably use this.
along with this
Also wondering if you think a single pump is still acceptable for these 3 rads in a semi long loop.
d5 pump.
Thoughts ?
I've also debated doing a entirely external rad solution with quick disconnects but its hard to find suitable external chassis for this now there used to be a nice one from i think mountain mods? but no longer available.
i expect if i wanted to do that id have to build one from wood.
probably use this.
along with this
d5 pump.
Thoughts ?
