To handle FX, that means you definitely need AM3+ socket boards. These will take athlon II as well as Opteron. Support for FX on non AM3+ boards can be poor, though some claim support for FX with a bios update - it typically is not stellar from what I have seen posted.
I'd definitely would only look at AM3+ boards. ASUS, ASRock, MSI and GIGABYTE are some good choices.
Doesn't matter when using an FX chip.
The FX chipsets are an entirely separate things from the FX CPUs - generally FX chipsets are the high end, including the most features, usually designed more for enthusiasts or powerful desktop users.
Differences vary, but reading the mobo feature list will highlight the important differences.
If you are looking at value to mid value boards, then biostar should also be in your list of boards to consider.
What you want to do with the system, and the price point you want to hit determines what you should get - there is no universal right answer, so if you can give us more to work with we could recommend better for you.
I think i would avoid the msi boards for the fx8120 and above, I have roasted two msi 990 boards with this cpu. the ones I am looking at are asus sabertooth and the asus rog extreme and the crosshair formula v.
digita vmr's, good heatsinks, atx form factor, over current protection onboard.
the exchange gigabyte board and the fill in board all died of vrm failure.
3 dead boards, three dead fx8120's. this fill in msi board is dieing at stock clocks as we speak.
the rma thing is not so bad, three hour drive over to tiger direct, exchange it and home. the b*#$h of it is rebuilding two computers every week. the other to get my 955 out so I can update the new boards bios.
this saturday i am exchanging this msi thing for a sabertooth.
