- Sep 15, 2007
- Small town Emlenton, PA
Is that canadian $$? Reason I ask is the Canadian $ has really done well in the last 2 years, not as good as the Euro, but very well.
EK-Supreme universal water block for all socket CPU's has been designed for the hardest enthusiast user. The base plate is made of electrolytic copper lapped and polished to +/- 0,0007 mm flatness. The top is made of quality POM Acetal.
Um, ok first of all your link leads to an empty cart. Secondly, I just built a loop for a friend buying exclusively from jab-tech. Here are the parts:ancalime, hate to burst your $200 bubble, here is a decent 120x3 kit with everything.
http://us-dc1-order.store.yahoo.net...re_id=yhst-65556269779593§ionId=ysco.cart
It's $250 without shipping (add $11). Sure you can save a few bucks here n there by getting components from 3 diff places, and then the shipping goes up.
Are we talking about the same OP? He has 111 posts so yes he does have access to the classifies.Peeps can argue all they want about used stuff is better, heater cores are cheaper. We are talking about the OP, new at this and doesn't even have access to the classified here until he hits 100 posts. So your solution isn't viable for a new WCer.
what does bending hoses and fitting clamps have to do with leak testing? All of those things you describe are easy enough, even for a first timer, in a case with sufficient room. There is little point in leak testing outside the case if you are just going to leak test inside the case again.And for a first time WCer, there is nothing wrong with setting it up outside the case and testing. It's a great way to learn about bending hose, fitting clamps, learning how to fill/bleed a loop. For a first timer it's the SMART way.
lol sorry didn't mean to get all heated up. For some reason "sorry to burst your $200 bubble" really fired me up though.Okay, you win. Just add hose, clamps, biocide, fans, fill port plug and we'll call it even.
I understand that, perhaps I just forgot how one feels when one first sets up water cooling. I just think having to leak test twice is a big waste of time but if one is worried enough and has enough time, by all means..And being careful and methodical on a first time WC setup is really what matters I guess. I'd rather someone learn about undertightening a clamp outside the case off the mobo and not getting water all through their PCI slots. Dry mount it all to get hose lenght right, then take it all out, connect it all up and fill er up. And then take it all apart and slap it in after no leaks etc. Just my thoughts, you can do as you wish, as I can too.
