- Feb 15, 2003
- Mesa, Arizona
what is the stock voltage for the venice? i cant get it past 2300mhz with 1.45v.. all of you seem to be at 1.6+ i thought i got another dud but maybe i an UNDERVOLTING it... let me know, thanks
EvilCloudStrife said:what is the stock voltage for the venice? i cant get it past 2300mhz with 1.45v.. all of you seem to be at 1.6+ i thought i got another dud but maybe i an UNDERVOLTING it... let me know, thanks
Hoot said:From my own experience, the burn-in, settle in, call it what you want, isn't as pronounced as it was back in the days of the Tbird and Tbreds. The Winchester and newer cores seem much more tolerant of higher temps than the 130nm stuff was and temperature is what the so called "burn-in" is all about. No matter how austere you are with your TIM, you wind up putting on too much. The "burn-in" is the time it takes for the excess TIM to exude from between the core and the base of your heatsink or water block. Depending upon how stingy you are with the TIM, the temp you are running at and whether you are using air cooling with an attached fan or not, govern the time "burning-in" takes. With an effective water block and cool water, it can take up to a few days. With warm conditions and a powerful (vibrating) fan on a heatsink, it can take as little as overnight. The warmer the TIM, the stronger the vibration, the faster the excess will displace from between the core and face of your sink. That's why many people used to run at a relatively slow speed, but high vcore while "burning-in". The point was to get the core and consequentlyt the TIM hot, but not try to run it too hard. Of course, running at a lower Vcore and higher speed can generate the watts as well as high vcore and lower speed. Remember, this is not a mechanical device. You're not breaking in a lawn mower, just getting the best thermal coupling between the core and heatsink.
Hoot
Super Nade said:WTF? 3250 MHz on the poll? That is unbelievable! Lets see some proof folks!
~3.3 is totally doable on phase. So those guys are either lying or have PC. So you can disregard those results as such.Super Nade said:WTF? 3250 MHz on the poll? That is unbelievable! Lets see some proof folks!
Super Nade said:I'm glad to know that 3.0 is quite a realistic target under water or TEC. Learn something new everyday!
Hoot,
Does Speedfan automatically show "water" when temps < 25C ?
really sorry to hear that ! same thing happened to me with my winchester (dud) i got fortunate with my venice tho ... i'm usuallly not so luckybaberpervez said:From EvilCloudStrife
"CPU: AMD Athlon 64 Venice 3200+ @ 2300MHz - my venice is a dud.. just like my winnie"
oops! Perhaps I was wrong there!
