- May 1, 2014
I'm total new to PC's. I built my first PC about 3 weeks ago and am still settling in and trying to work out what everything dose. I am also duty bound to stop fiddling and start working on it but wanted to do a mild overclock first just to squeeze the best performance out of what I have. OC was all a bit confusing for someone as new as me but i sussed out that if I wasn't going to be really pushing it I could just work with the multiplier and the Vcore. What I am confused about is the memory speed,
i7 4930K
Palit GTX 780 SUPER JETSTREAM
Corsair 860W AX860i
Corsair H100i
Crucial 240GB
ASUS P9X79 WS
Kingston HyperX Beast 32GB (4x8GB) Memory Kit 2400MHz
and some HDD's
1.40 Vcore
45 multiplier
4500MHz
with P95 it seems to be quite happy the core temps are from 70 to 80 with a few little spikes up to early 80's. I came down from 1.44/45 stable but too hot, mid too high 80's and could maybe work my Vdown a little more but I'm happy if it is.
it did a strange thing where it was fine working and gaming but if i let it go into sleep mode for to long when i hit the keys to recover all the fans went to full blast and stayed there with a dark screen till I pressed the power button and shut it down then when i start the first time it comes up with the unsuccessful OC screen, I shut down again and reboot and it's fine. In the end i just disabled sleep mode and now all's good again.
The memory is what I'm confused about, I have it at 1600 as a middle ground as I'm clueless on whats best, the timings say 9 9 9 24 1
The ram is 2400 with CAS 11-13-13-31 Timings on the web page. I'm worried about putting these timings into the bios and ramping it up to 2400 as I've been told it will show little performance increase and a lot more strain on the system in heat? If I set it to a different lower speed like 1600 how do I know the correct timings to put in?Or do I just leave it be and it'll do it it's self.
thanks for any help on any issues or all if there all the same one.
i7 4930K
Corsair 860W AX860i
Corsair H100i
Crucial 240GB
ASUS P9X79 WS
and some HDD's
1.40 Vcore
45 multiplier
4500MHz
