what i said is that if you are not an extreme overclocker, plain water offer the best ratio of performance and price,
air-too low
water-about right
water + tec-needs too many extrass
phase change-expensive, cheap if one has the knowledge
it seems that you are afraid of water, but when you take all of them in comparison, air is the safest, then the vote goes to water, a sealed system will be always ok with water, leaks are the problem, but that goes to anything,
then the rest you need to worry about electric bill, and condensation which can be a ***** sometimes
but if you want the best and the extreme one, (you are in extreme section) that can be used anytime, it would be phase change all the way
