Yes you are correct. I was being a bit facetious, when I said "overclocking to a decent degree" I should have stated that... my bad. Unless he's dropping LN2, which HE BETTER , he shouldn't need all 4. I mean... what's the point of any computer... if not for extreme benchmarking???!!!
Conversion cable or another PSU that has 2 8 pin CPU jacks... and I dont know who has those to be honest (well actually, I think my Seasonic X750 does)...
Actually the SR-2 will take 4- 8pin connectors plus the 24 pin main, if you plan on overclocking to any decent degree !
Anything, and fast.Yes this is for fun and learning...........sooooooo now tell me what will be what this machine is/should be "designed for doing?"
Anything, and fast.
What degree is a decent degree?
well like i said this kind of setup minus the SAS drives .............
However, if you plan on buying it just so you can play, have fun, and push the limits of computing... that is a perfectly good reason! As stated before... join us in the Benching subforum, and we will help you "get the most" out of it
.....FAH GPU client. ........ SMP FAH ...seti or the Rosetta team .
w i know the teams here would love to have you onboard if you setup it just to run the programs i talked about.
Dual ported SAS's with the RAID controllers I have!!!! Seriously? They are all Enterprise class Fujitsu Limited's.
My disk I/O and data transfer speeds not to mention stability will blow ANY SATA configuration you can hope for!!!!
