Probably not possible for two reasons:
1. That HP box store computer bios probably is bare bones and has no tools with which to overclock, i.e., no settings that can be changed to speed up the CPU.
2. To expect to increase that model CPU speed by one whole ghz is asking too much unless you have extreme cooling.
The best you're going to be able to do with that mobo is a Athlon 64 3800+ (2.4 GHz / 2000MT/s); 512KB L2 cache.
Sorry, but it's time to retire that 13 year old compter and get a new one.
Amen! Any upgrade you make to that system will yield very poor improvement to cost ratios. Don't buy a mass produced, box store computer next time. Build your own using quality components that are configurable and upgradeable.
How much would it cost to build a gaming computer from the ground up?
Cody, the parts list I gave above is the very minimum you should consider in order to play your TERA game but I would really like to see you throw in another $100 and move up to a 64-bit version of Windows and another $15-$20 and move up to 8 gigs of ram instead of 4 gigs:
Windos 7 Home Premium OEM 64-bit: http://www.newegg.com/Product/Produ...tion=Windows+7+Home+Premium+OEM&x=-785&y=-112
8 gb RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820313355
