greenman100
Disabled
- May 18, 2003
- Thread Starter
- #61
$54.19 is not the same $30 shipped as the other one, but it is the best I've found
i think the leds on ram are a great feature. it really tells me whats going on by just looking at the ram.Fyberwire said:It was an idea put out there just for the sake of having it, it doesn't really serve a purpose, like the LEDs they put on ram sticks nowadays.
Anyway... I had another idea while admiring UberBlue's work on his Dual core 4 blower hack mod from hell creation.
How about mounting a big radiator (At least a dual 120mm) on the top of your case, strapping a gigantic blower to it, and then running tubes from the inlets on the blower to the front and back of the case where they would be integrated into meshed/stealthed intakes. This would also create an optimal point for installation of a dust filter, since you would never have to clean your radiator our if you did it that way.
mils128 said:Ok How about.
Put some Hydrolics on the Case Feet.
Get a Second PSU
Pelt it
After your heatercore duct it with a 120mm foan blowing out.
Pit your t-line in one of the case feet so that you turn it updide down and everything fills up. this would require mounting everything with screws.
make a hydrolic from door.
Add Remote COntrol to the hydrolics and Make it bump up and down and the door oppening and closing.
if that case is goona have a door in from make that hydrolic and clear.
etch a pimp drawing.
Att some CCFL to make it look good.
Add a fan to the back of the mobo tray.
put a small fog machine inside with some green ccfl's and hook those up to the remote.
Probally a 3rd PSU will be in order.
These are just some fun suggestions and i was bored out of my mind so i typed them.
ls7corvete said:I can see the advantage to the tall case thing but I think you can do just as much cooling in a lot less case.
ls7corvete said:Hey I just thought of this......
Nice challenge for you
How about one of these cases?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=33871&item=5133766184&rd=1
It would take alot of drilling but in the end you would have something similar to a stacker.
You would have to keep looking on ebay and find one near you or it would not be worth the $$ to ship.
