CPU: AMD Phenom II X4 955 3.20 GHz
Ram: G-Skill 2x 4gb DDr3
MOBO: ASUS M4A87TD/USB 3
PSU: 650 watt
CPU Cooler: ARCTIC COOLING Freezer 64 Pro 92mm Ceramic CPU Cooler plus 4 other fans
GPU: AMD Radeon HD 7800 Series
HDD: 500 gb
PSU: 650 watt
HDD: 500 gb
Depends on your chip, board, and cooler. Mostly silicone lottery though. Try to get as high as you can and let us know. Make sure to keep an eye on temps and your voltage. I am not sure what the max on either of those are but those are important in overclocking. I think you should be able to get around 3.7-4.0. Here, check this guide out: http://www.overclockers.com/forums/showthread.php/596023-Dolk-s-Guide-to-the-Phenom-II
