You see higher bandwidth in AIDA64 tests with the same kit/speed and higher core-count processors... not sure where it stops scaling, but I do recall seeing that. I don't believe it translates to acutal performance increases, but I could be wrong (@Woomack).For me maybe just simply everyday use and latency questions.
This response doesn't really answer my question... feels like an answer to a different question, lol. But yeah, I can agree with that from a home user standpoint (as do many others in the other thread, lol). Most home users don't need more than 32GB for sure and 16GB is now the 'base' for a 'gaming' machine as you can eclipse that amount easily if you aren't paying attention (have lots going on and start a game, or play modded games). But servers can and do. I never heard about that rule of thumb/lopsided-ness before though.No evidence from common benchmark comparisons makes me believe more than 32 GB is needed.
As I'm trying to work out in another thread, ram configuration does play a part, big or small depending on the use case. While I don't have any, DDR5 8GB modules are considered trash tier, 16GB modules are the new entry level and above that you may get some rank advantage, at the same speed and primary timings. I have seen this on DDR4 modules which I'm still testing/digesting the results. My laptop came with 1Rx16 modules which really suck. In enthusiast desktop land, ram is usually 1Rx8 or 2Rx8, with 2R giving an edge in some more ram intensive workloads. Running 1 or 2 DPC can impact performance, again assuming same clocks and timings.If the software can't use the RAM, then the RAM is just a waste. For example, If you never pass 16GB, then it doesn't matter if you have 32GB or 192GB RAM, it will perform the same (assuming that the RAM clock and timings are the same). However, higher RAM capacity usually means more relaxed timings and/or lower frequency. If I'm right, then 16GB and 24GB modules will perform not much different, but 48GB are already rated much lower.
Who is saying that? Maybe in a specific context that might make some sense. In a more general sense, it is more like enough vs not enough. For a gaming system, 8GB of system ram is only ok for much older and less demanding games. 16GB is a nice spot to be at although latest demanding titles may be starting to push upwards on that, especially if you run a ton of stuff in the background at the same time. I feel with DDR5 generation starting point should be 32GB, in part because of potential near future demand for games, but also because 8GB DDR5 modules apparently suck. This is regardless of core count.Out on the web im seeing postings of 2 GB per core is low , 4 GB balanced and 6 GB of RAM Capacity per core is on the high side.
So to the previous question this isn't exactly about total capacity but module capacity and configuration.
I still haven't got hands on with DDR5 at all yet. With DDR4 1R 2DPC = 2R 1 DPC or near enough. The difference with DDR5 is that 2 DPC seems to come with a much more severe max clock penalty than DDR4, regardless of rank, so that may lean towards going to 2R 1 DPC for best performance. e.g. For Zen 4 official supported speeds are 5200 for 1 DPC, 3600 for 2 DPC. Can I assume the 2R DDR5 modules probably start at 32GB? I still have no short term plans to get any so will see where market goes.DPC impacts the performance almost the same as single/dual rank. However, I was comparing DDR5 single and dual rank kits and there is barely any difference. In DDR4 it was significant in some tests. It's only that motherboard manufacturers won't guarantee 2 DPC setups above ~6000 while 1 DPC can go up to 8000+.
