- Jan 5, 2005
- Ormond Beach, FL.
This is the build. It's going to be PETG.
Nothing can fit where the res holder goes since the GPU is in the way.
I can use a single bay res, but that "may" kill all three 5 1/4 bays unless I use 90 degree angles on the rad. I'd like to put a Blu Ray burner in one slot.
Within the hard drive bay, you can install a pump holder, but that will kill all of the bays, even if it is a small res. There are two hard drive holders with grooves. The bottom one slides on where the pump holder would go and the top one slides on the top of the bottom one. That leaves no place for the hard drive.
The bottom is out because the PSU shroud goes up to the bottom of the board and extending to the from about half way where the bottom fan is.
I was thinking about something horizontally on top of the PSU shroud, but that leaves the PSU out of touch for adding more cables, etc.
They call this (Ethoos Luxe) a full tower.... more like a mid tower. I'm like totally stuck deciding....help?
