- May 29, 2005
To clarify the thread title, what main components (outside of video cards) are the general go-to parts to get for a 4-6GPU dedicated mining rig? Of course it would be nice to get the ASRock H81 BTC board, but those are so hard to find for retail that many people look for cheap alternatives. The real question is... what are the best alternatives that won't break the bank?
CPU
I know many use the cheaper sempron/celeron CPUs, does the lack of available cores hurt the mining power in a way?
Motherboard
What motherboards are able to handle 4-6 GPU connections with (presumably) powered risers without burning down a PCI-E slot?
Memory
How much RAM do you generally put into the systems? I've found that on at least vertcoin 16GB of RAM may be necessary in order to mine with 4 GPUs with high TC and Intensity.
Case (or lackthereof)
There are many professional-looking racks that were hand-made, but for those without the skill (or without the tools) is the "best" setup using milk crate-style setups with some PVC pipe to hold the floating GPUs?
Power Supply(ies)
We've had a discussion on the value of getting a high-efficiency PSU (gold/platinum) over Bronze and it looks like while ideally it will be saving you money at the wall, it will take months (and possibly a couple years) to earn back the cost of power that was saved. Which type (single vs multi rail) and how much wattage do you shoot for? What do you do when a single system is having trouble with even two power supplies? Have you just done the paperclip mod to force a PSU?
Risers
Which risers are generally the standard? Do you go with the powered variety to be safe? Are you using the ribbon cable style or have you moved over to the USB plug versions?
Cooling
What do you plan to do about cooling everything? With Spring then summer in the near-future using the outside environment with windows open will no longer be an option. How do you plan to cool your system(s)? Are you setting up a dedicated air conditioner or just hoping for the best in your basement?
Power Delivery
Are you making modifications to your house to assist in the proper amount of power delivery to the wall jacks you are using to prevent blowing a fuse/circuit? If so what have you had done and how much power from the wall was necessary for you to have it done?
Thanks for your help. Using PCPartPicker probably wouldn't be a bad idea if you have a general build that you follow. I can include those in the top of the post/thread if we have a decent number of agreed-upon submissions.
CPU
Motherboard
Memory
Power Supply(ies)
Risers
Cooling
Power Delivery
