- Apr 16, 2011
- Missouri
I'm sittin here bored so I figured, why not try and make my pc cooler?
It will be the rear fan on my NZXT Phantom 630. Here are the options...
http://www.frozencpu.com/products/1...25mm_UV_Reactive_PWM_Gamer_Fan_-_UV_Blue.html
http://www.microcenter.com/product/351003/Shark_Blue_Edition_140mm_Case_Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835220056
Which one should I use? Also, there is a place on the bottom of the case for 2 fans should I add any, as I have a lot of fans and even more time on my hands.
Thanks guys, all opinions/facts are accepted.
