So I have two choices of RAM
a) G.SKILL - which is 2666 @ 15-15-15-35
and
b) PATRIOT which is 3000 @ 16-16-16-36
If my math is correct ((T = 1 /f) * CL), based on what I can gather the total latency for these is 11.25ns and 10.67ns respectively.
(Seemingly making the PATRIOT the better choice based on total latency)
The G.SKILL I have tested so far to 2933 @ 14 CL.
This would equate to a total latency of 9.54ns.
The PATRIOT I have tested so far to 3200 @ 18 CL.
This would equate to a total latency of 11.25ns.
I may be able to tweak that PATRIOT better, but it seems I would need to get it down to a CL15 (or a speed of 3800) to have a better latency than the G.SKILL.
I'm not sure that would be possible to get things that tight (though admittedly I haven't tested yet).
So here are my questions:
1) Based just on the math above - isn't the G.SKILL the better RAM in this situation? Based strictly on performance?
2) The G.SKILL gave me a lot more problems than the PATRIOT. The G.SKILL required changes in timing, voltage, and modification of some other settings (GDM) in order to boot above 2400 with my Ryzen 3. It seems stable now, but it took some work. The PATRIOT however worked fine at 3000 simply by selecting the XMP profile and seems to be working fine at 3200 with just a small increase in voltage.
Based on the fact that the PATRIOT seems more compatible out of the box, should that account for something? Is it worth a latency drop of almost 2ns?
I may be totally missing something here as this is all kind of new to me - so please feel free to school me
and
