- Jun 1, 2005
Hey,
I built my new PC and found that my CPU is a MASSIVE bottleneck and wont really OC that well.
I've had to RMA my PSU so haven't finished trying to get my 3200+ Venice to OC properly... but at present I can't get my FSB up to 230... even if I drop everything else right down.
I had hoped to get my 3200+ clocking at about 2.5ghz but can only muster a pathetic 2.28ghz. So assuming I can't sort this chip out, I will sell it and buy me a newer, better CPU.
Which CPU to buy? I would ideally like to spend £350 / £400 max and guess I would be torn between the new AMD Athlon 64 X2 Dual Core 4400+ and AMD Athlon 64 4000+ San Diego 90nm. (Don't know if there is a comparible venice in that price range?).
I guess the dual core would be the better processor, however, would I benifit from a Dual Core for gaming? I remember reading something somewhere that said Dual Core wouldn't work for gaming... is this true??
If anyone could shed a little light on the dual core for me or if anyone knows of any benchmarks between the 2 CPUs i mentioned, that would be brilliant!!
Cheers, Slack
Cheers, Slack
