Which of these should I get?
z3r0
Oklahoma
Specs in sig. I will also be Overclocking.
Another stick of Kingston 512mb HyperX PC2700
or
Should I get the:
AMD Athlon XP 2500 Barton - $86
AMD Athlon XP 2700 - $113
AMD Athlon XP 2800 Barton - $136
Or, (insert chip here). I am not looking to spend over $150. I have the Asus A7N8X Deluxe Retail mobo.
Any unlocked Barton is better than 2700+ T-Bred (which BTW OCs similar to 2100+ T-Bred.)
Web sites usually do not list codes z3r0. If they do, they tend to charge a premium for it. Ordering from most stores is shot in the dark.
The only way to buy a chip that you know for sure is unlocked is if you buy it from a corner computer shop so you can see the code on it before you buy it.
Or to pay extra & get a CPU from web sites that post codes. I know excaliberpc.com posts codes, but would you belive it, the code they used to post for 2500+ was actually a code for a locked Barton (!).
Or to maybe get a 2100+ at newegg, I believe there are no locked 2100+ and newegg used to guarantee then being T-Bred B's. They're $62, good overclockers but only have 1/2 the cache Barton has but they do 2.3 GHz so...
those are your options.
c627627 why don't you ever recommend the XP 1800+? It will do at least 2.3, with a minor voltage boost and can max out at 2.4-2.5GHz with the right cooling, and is still a few bucks less than the XP2100+.
1800+ DLT3C B (not A) will overclock further than 2100+ B absolutely.
However, 1800+ DUT3C usually will not, 1800+ come in locked week 39s, (I think they stopped making 2100+s before week 39 so 2100+s are always unlocked as far as I know) plus here in the US, if we wanted to buy a T-Bred B from newegg.com, they guaranteed 2100+ to be B's, they did not guarantee 1800+s.
Most importantly lower range (12.5 and under) multipliers vs. higher range (12 and up) multipliers: 2100+ is 13x (higher range) and it posts all multipliers (lower and higher range).
However, 1800+ will only post lower range multis on nForce2 mobos such as Epox 8RDA+ and many others so if you have PC2100 RAM, and you really need those 14 and 15 multis, you can only get that with 2100+ T-Bred B without modding the chip.
2100+ do 2.3, even on slightly below average setups whereas lower rated DUT3C CPUs did 2.2 on those setups.
1. Unlocked 2500+ Barton.
2. 1700+ or 1800+ DLT3C B (not A).
3. 2100+ B.
4. Other DUT3C Thoroughbred B's.
