Hello everyone,
It's been awhile since I've put in a fan on my computer and well, I kind of forgot the difference between the following plugs
So, my fan doesn't have the smaller plug but it does have the two 4 pin molex plugs.
A black and red wire leading to one which then leads to the yellow black black red molex. Does it matter which one gets plugged in?
Also, is there a way to quiet it down? One of my computers was overheating so I put another exhaust fan in and it worked flawlessly. Unfortunately, the 4 pin molex is the only option for that computer and I was also wondering the best way to quiet the 7 year fan down as it's pretty loud full power.
And finally, would oil used for my vehicle work in oiling the fan? Does the sticker covering the plug need to be put back on after it is oiled?
-Thanks Everyone!
-Thanks Everyone!
