Hey Water Cooling experts, I would like your opinion. I recently installed a water cooling setup on my CPU for best performance while overclocking to run benches (I'll run sub-zero later). I mounted a Photon 170 Tube Reservoir D5 Vario Pump combo on the back side of my CM HAF 932 in front of a fan to cool the water a bit, however I'd like to put every thing inside the case. Do you think this is a good Res? Monsoon Series Two Premium D5/MCP655 Dual Bay Reservoir.
http://www.frozencpu.com/products/1...ack_w_Black_Trim_M2-D5P-MB.html?tl=g30c97s152
Here is how I have my rig setup now.
I also have some red Primochill Advanced LRT tubing so I can use less tubing and maybe get better performance with the res closer to the cpu.
Thanks, TJ
Thanks, TJ
