QuietIce
Disabled
- May 7, 2006
- Anywhere but there
Interesting to see speed doesn't really matter (or favors lower latency) on the i-series either. Thanks for posting ...They say a picture speaks a thousand words, so.....
That is surprising to me I do not think it would be the case on X58 as QPI is tied directly to mem speed (as is CPUNB speed or uncore)
From what I read the other day on p55 though many boards say QPI on p55 they do not actually have one because QPI was developed for interCPU communication and 1166 will never support that.
You mean the RAM test results or the Intel stuff ...?none of this is really surprising to me, its all stuff we have had access to for ages now.
It seems on X58 his claim has some weight to it
if you want a kicker watch your latency drop when you removed stick of ram. the LGA1366 platform takes a slight latency hit (ie increases) when you use the third channel.
interesting, so dual channel would be better for 2d benches?
well programs that need fast access to ram but given how fast things are now. DDR3-200 with cas 8 or cas 9 in dual imo would be best even for gaming. still the big kicker would be to have a ssd to improve latency from HD to ram for lvl's ect to load faster.that would explain the lower latency on my P55 vs my X58
well i am on it but i have done any thing for them lately. not only that but i knew about this before i joined up on the bench team. it goes back to the dual vs tri reviews going on when LGA1336 hit the streets. they were showing = BW with tri DDR3-1333 cas7 to dual DDR3-1600 cas8. the other thing was they also showed the tri setup to have a higher latency then the dual on LGA1336.You on the benching team?
EDIT: ARGH!!!!
Yes dual is better for benching 2D for certain tests in more than one way
So the QPI (at least for memory access) fills the same roll as cpuNB speed on an AMD ...?1156 does have QPI, it's what links the on-package NB to the CPU core itself.
DMI links it to the PCH on the mobo.
That makes QPI very, very important for memory performance, like FSB was back in 775 days.
vsDMI 2.5 GT/s
Intel® QPI Speed 4.8 GT/s
# of QPI Links 1
QPI or DMI = HTT, not sure if they changed the names around again for HTT.So the QPI (at least for memory access) fills the same roll as cpuNB speed on an AMD ...?
you could say using the extra channel is a good thing for the extra bandwidth. though its a weird thing to try to explain since i havent been around much. i would rather have a lower latency access to ram then higher bandwidth. since the cpu will only need so much, what would be the point of throwing extra at it. like driving a super car on a american highway, yea it can do 200+ but the speed limit is 65.
i guess after that point, you are getting to diminishing returns. with regards to what we are talking about. not only that but using the extra channel does increase cpu temp as well, not by much but 2-3c. ocing the cpu should be better with using dual channel on LGA1136.
yea i read that in wiki but what can i say its the wiki. not really that solid for info since anyone with a login can change things. not even back in the day did they mention the QPI/DMI were PCIE buss lanes being used. though this link hereThing is, the DMI is a 4x PCIe 2.0 link with intel bonus features.
The QPI ratio set in bios directly effects benchmark speed, meaning it is used for something.
The IMC on package also has the iGPU in it, it's a G45 on crack essentially, with the PCIe ripped out and stuck into the cpu core. It's my understanding that the IMC talks to the CPU via QPI. Seems like it'd have to, as the 2.5GT/s DMI can do isn't even close to what people are posting memory bandwidth wise.
