- Apr 24, 2007
- Liverpool-UK
Why are their huge price differences between memory with basically the same specs?
It's always baffled me as to why different memory modules which appear to have pretty much identical specification's, can vary so ridiculousley in price between different brands/models.
E.G-
-GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC)
- PC6400 800MHz CAS 4-4-4-12
- 64x8 DDR2 BGA Chips
- 240pin, Non-ECC, Un-buffered DDR2 SDRAM DIMM
- Aluminum Heat-spreader
- 6 Layers Ultra Low Noises Shielded PCB
- Lifetime Warranty
- 1.9V-2.3V Power Supply
£37.59 inc VAT
-G.Skill 2GB DDR2 HZ PC2-6400C4 (2x1GB) CAS4 Dual Channel Kit (F2-6400PHU2-2GBHZ)
- Package : 2048MB kit (2x1GB) dual channel pack
- CAS Latency : 4-4-4-12 (PC2-6400)
- Test Voltage : 2.0-2.2 V
- Speed : DDR2 800MHz (PC2-6400)
- Type : 240-pin DDR2
- Error Checking : Non-ECC
- Registered/Unbuffered : Unbuffered
- Quality Control : Comprehensive rigorously tested in pair at dual channel environment
- Warranty : Lifetime
£93.99 inc VAT
Prices from following link:
http://www.overclockers.co.uk/productlist.php?groupid=701&catid=8&subid=813
I'm not sure that's actually the best example as I think one uses Micron D9 chips and the other doesn't, but you get the gist. There are MANY other example's out there.
So why is this?- it seems ridiculous to me that the prices can vary by up to increase of 300% for same/very similar spec. mem. modules for what i'm guessing might only be 1 or 2% performance increases.
Am I way off the mark here? Are the performance increases actually noticable? Or do some people just have cash to burn?
E.G-
- Lifetime Warranty
£37.59 inc VAT
£93.99 inc VAT
