Just wondering out of curiosity, when comparing DDR3 vs DDR4 at same frequency, with DDR3 it is common to see CL9/10/11 for 2133/2400MHz memory, but with DDR4 it's usually CL14/15. I suspect it's because of lower stick voltage and probably memory controller too? It's interesting that for example 6700k that supports both DDR3 and DDR4 ram can only use low profile DDR3 RAM, so it's usually low bandwidth RAM at about 1600MHz. On the other hand the 4790k can with overclock and a good motherboard do 2666MHz-2800MHz DDR3.
So really, other than the fact that new chipsets and processors support it, what advantages does DDR4 have over DDR3?
