Greenman100, you want to spend that extra $30 for decent memory because value RAM isn't properly speed binned. Unbinned UTT is often garbage, and quite unpredictable. The odds are not great - we're talking about a memory IC that is tested to ABSOLUTELY NO standard of operation or integrity after fabrication (Hence the name, UnTesTed). As such, UTT ICs in value RAM specified for CAS 2.5/3 operation are quite unlikely to overclock particularly well - they haven't been binned to see if the ICs are:
~ Capable of overclocking past spec (200 MHz)
~ Capable of running with tight timings
~ Capable of taking high voltages
A poorly manufactured IC that would have made it into the trash can had their been a standard of integrity/operation at fabrication (which there isn't for UTT) has a potential for sudden death at higher voltages - it hasn't been tested to any standard of integrity, and hasn't been speed binned aggressively by a memory module manufacturer.
225 MHz 2-2-2 at 3.3V doesn't sound like a lot, but may well be unachieveable with unbinned UTT.
