- Mar 10, 2012
Hi All,
I have a 2500k running at 58c in BIOS and 49-53c in windows at idle.
Running prime95 I hit 78c, no more. Ambient room temp is 26c.
The temp seems hot - is the chip faulty?
I have an OC of 4.4Ghz, Vcore fixed at 1.3v (if I raise Vcore to 1.328 the temp exceeds 80c when running prime.)
Set up:
ASRock Z68 Extreme 3 Gen 3 MB
DDR3 2x4Gb 1600 r.jaw RAM
Synthe Mugen 2 with stock and additional 120mm fan, push/pull config.
Fractal Designs R2 case
2 x 120mm fractal designs case fans. One on rear, the other top rear.
passively cooled HD5770 GPU, stock speeds.
Seasonic 650 gold PSU
I have the fans set on the mainboard as follows:
CPU 1 = Synthe fan (4pin mb connector) set at 55c and level 1 target
CPU 2 = rear chassis fan (3 pin)
Chassis fan 1 = second PWN fan on cooler (4 pin set to same targets as CPU fan 1)
Chassis fan 3 + top rear case fan (3 pin) level 1 target (1 = slowest)
Speedstep enabled.
C3, C6, Package C disabled
PLL overvolt disabled
Core current Limit = 150
When running prime the fan speeds ramp up to what appears to be full speed (1000-1360rpm). I have the fan speed set at lowest level at idle because I want a near silent rig at idle (used as HTPC) but high fan speed is fine for me when gaming. If I set the target temps lower (45 or 50c) idle temps drop to high 40s but fan noise is unaceptable as they run constantly at full speed
I reapplied thermal paste (using 25% silver compound), size of a pea, unspread. Did not change temps. I ran the same cooler on my C2D E7300 and the fans rarely went full speed, sometime the CPU fan completely stopped.
Your thoughts...
Set up:
Speedstep enabled.
Your thoughts...
