What slots are available??
So is the PCIe X1 slot blocked or free?
It sounds like he only has the gpu installed so that would leave 2 PCIe x16 slots and 1 PCIe x 1 slot and some regular pci slots free.
Can't recommend a specific card unless you tell us what wireless speed you are trying to achieve and what band you are using (2.4 or 5ghz). There are several options here to look at. If you're running wireless N then that top result from ASUS with the rebate looks solid. If you need AC speeds you're going to have to spend more....
How would i do that with the phone line I have going through the cheap router the cable company provided?
Tachi donot believe that is what is being suggested. They are proposing using another router connected to the remote computer as a bridge to the wireless router that is supplying the Internet.
