- Mar 7, 2008
The resetting of (some) settings typically only happens on a major update, twice a year. The routine monthly minor updates don't usually do that. If there is some genuine reason to need to reset settings during update, fine, but is it that hard for them to store the user setting and restore it after update? When you multiply with many systems it gets tedious to check and correct them all manually. I did debate at one time if it would be possible to identify all the customisations I do for each install, and stick it in some super batch file, preferably working on both home and pro versions. Then I can just run that to restore sanity. Some like default browser isn't easily automatable if even Google can't do it for you when you install Chrome... they just direct you to the setting to change it yourself.
Haven't come across the disabling of the threat protection. That's particularly interesting given how hard they make it to achieve if you do want to disable it...
