- Nov 16, 2003
- Cleveland OHIO
guys im stumped, and frustrated
Working on the presentation that determines if i graduate with a bachelors in electrical engineering or not, and windows has failed me yet again.
All i want to do, is share a folder, a drive, ANYTHING. It wont. it used to, but suddenly, it wont. Nothings changed. Windows firewall is off. Ive done the most unsecure idea and left a drive shared to "everyone" with full permissions. Nada. Cant connect from the mac i'm using, from any other windows PC..it just says "Cannot access share"
Everyones on the same homegroup. Said finiky PC refuses to connect to anything else also. This problem just sort of started getting worse out of nowhere. First i couldnt login over the network, had to login as "guest"..it would show me a few folders/drives but only allow me to access the public ones. Now, nothing.
Im doing renderings/CAD drawings on the windows PC and incorporating them into a powerpoint on the mac. Its adding TONS of time to keep transferring to a USB drive.
I have half a mind to see if solidworks can run on WINE rather than try and fix windows. Again. Any ideas guys?
Thanks in advance.
Thanks in advance.
