- Dec 9, 2009
- Canada
My rig consists of a an SSD and a regular HDD. My windows, obviously, is stored on the SSD and I use the HDD for miscellaneous storage. And everything was working perfectly. Then I bought a new storage drive, because I needed to use the old one for another build. So I installed the new drive, assigned it a letter and carried all of my files from the old drive onto it. I then formatted my old drive, partitioned it and removed it. Everything was working fine until I noticed that my computer would no longer sleep. Once I turned it off it would not boot up. With the error, "Bootmgr is missing." So I Googled and Googled and found a common fixes for the problem, but they didn't work for me. This includes putting in my Windows Disc (Windows 7) and pressing start up repair, as well as opening the command prompt and using Bootrec.exe. Both did not help my problem.
Then I put my old drive in a new computer, installed another version of Windows on it and booted up. I was prompted with a boot manager, asking me to choose between that new OS as well as Windows 7, but there was no Windows 7 on the disk. So from that I believe that the boot manager was somehow stored on my old drive and not on my SSD, does that make any sense?
Anyways, now I have no way to use my computer at all. I was wondering if anyone had any ideas of how to fix it. Or maybe a way that I could atleast boot into Windows? I've heard that you can use the Windows disc to load Windows without a boot manager. But I haven't been able to do that.
So any suggestions would be helpful. I would like to avoid doing a fresh install if possible. I want to at least get on my computer one more time, because there are still some important files on the SSD.
