Leegit Member Joined Apr 4, 2013 Location Kansas Dec 24, 2013 #1 Can someone please debug these two dump files I have attached? Need to figure out what hardware is failing and I can't install the debugging tools for some reason. Thanks Attachments Minidump.7z 29.7 KB · Views: 13
Silver_Pharaoh Likes the big ones n00b Member Joined Sep 7, 2013 Dec 24, 2013 #2 Leegit said: Can someone please debug these two dump files I have attached? Need to figure out what hardware is failing and I can't install the debugging tools for some reason. Thanks Click to expand... I'm not an expert, so I can't really help you...but: the 122413-9469-01.dmp file was caused by the Nvidia display driver. Are you overclocking the Nvidia card? If so, the driver itself may have crashed causing the BSOD.... The other file is a Page Fault in a non paged area caused by ntoskrnl.exe... Not sure what to do to help. I only have the bluescreen viewer to figure out what causes my BSODs Sorry I can't be of more use.
OP Leegit Member Joined Apr 4, 2013 Location Kansas Dec 28, 2013 Thread Starter #3 No worries. You gave me the information I needed Can't remember if I was overlocking the vid card or not... hmm... back to testing
OP Leegit Member Joined Apr 4, 2013 Location Kansas Jan 1, 2014 Thread Starter #4 Another one if you could be so kind Attachments 4200_BSOD_Crash_in_Civ5.7z 17.4 KB · Views: 10
Silver_Pharaoh Likes the big ones n00b Member Joined Sep 7, 2013 Jan 1, 2014 #5 Leegit said: Another one if you could be so kind Click to expand... Of course! According to http://www.carrona.org/bsodindx.html#0x00000124 Looks like it might be a bad driver or bad hardware. Let's hope not bad hardware. Oh and it was hal.dll -- that's the driver that caused the BSOD. hal.dll is Hardware Abstraction Layer, to me this might be a hardware issue..... Not good.
