yes, uninstall wmp, then reinstall it, but make sure you know which codecs are installed if any, so that you can reinstall them, I usually use the defiler pak ver 1.19, I watch a lot of anime, but I think you can get codecs from ms's homepage (If you absolutely MUST deal w/ them )
Or, try upgrading to wmp ver 10 if it's not already upgraded.
