- Jan 12, 2013
- Colorado Springs, CO, USA, Earth
Sometimes when I turn my computer on, it will fail while booting into Windows and just freeze up. I have to restart the computer to get it to work. The computer always turns on fine and the hardware all works, but it's loading into the OS I'm having issues with every now and then.
It started when I got this Blue Yeti USB microphone and plugged it into my PC, which had weird issues and sometimes needed to be re-plugged in in order to work, and sometimes while booting up I'd get a blue screen. At the same time, I just overclocked my system a bit. Not sure if it was the mic's fault or the overclocking but occasionally it just fails to boot up.
I just turned all my overclocking off, everything back to normal and I want to see if that will fix anything. Does anyone know why it's doing this?
Here's my system's specs:
OS - Windows 7 Ultimate 64-bit
Motherboard - Gigabyte P45T-ES3G
Processor - Intel Core 2 Quad @ 2.4GHz Q6600
Memory - 8GB of DDR3 (G.Skill Ripjaw @ 1066MHz)
Video - EVGA NVIDIA GeForce GTS 450
Storage - 1x OCZ 128GB SSD (OS)
1x Seagate SATA 750GB HDD @ 7,200rpm,
1x Western Digital IDE 160GB HDD @ 7,200rpm,
910 GB Total
Power Supply - Ultra LSP650 Pro 650w
Optical Drive - DVD Multi Recorder
Rosewill RCR-IC001 40-in-1 Card Reader
Heatsink - Rosewill RCX-Z2
910 GB Total
