micjmac Member Joined Jul 14, 2010 Nov 17, 2011 #1 Is there a way to get a program to run in the tray if the program doesn't have that setting? Real Temp used to work in the tray for me, but maybe they took that option away in the most recent version?
onefstsnake Member Joined Nov 20, 2007 Location Fburg, VA Nov 17, 2011 #2 Im using RT 3.40 and it works fine in the tray. Maybe try an older version.
G grubbster Registered Joined Dec 17, 2010 Nov 18, 2011 #3 A program called taskbar helper will let you move any program to the tool tray.
