And by the way switching to AHCI in Windows 7 is easy but difficult in Windows XP.
To be able to power on / plug in your internal hard drive without shutting down your
Windows XP computer:
1. Check to see if file
iaStor.sys is in your \Windows\System32\Drivers\ folder. If not, go here and download the Intel Matrix Storage Manager:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=17882
File names change for updated versions but for the example of IATA89ENU.exe file downloaded to C: drive: Start Menu > Run... > C:\IATA89ENU.exe -a -a
Now go to \Program Files\Intel\Intel Matrix Storage Manager\Driver to find and copy iaStor.sys to your \Windows\System32\Drivers\ folder.
[Note that you can't just double click on IATA89ENU.exe]
2. Figure out which ICH your motherboard uses by looking it up here:
http://en.wikipedia.org/wiki/List_of_Intel_chipsets
If it's ICH8R, ICH9R, or ICH10R, then copy and paste the corresponding lines below into Notepad and Save As a file with a .reg extension. Double click on it > Yes.
3. Reboot into BIOS and switch to AHCI mode.
4. When prompted, select Install from a list or specific location (Advanced) > Next > Don't search. I will choose the driver to install. > Next > Next > Have Disk… button > Browse… to
\Program Files\Intel\Intel Matrix Storage Manager\winall\Driver
Done and here are the reg files:
For ICH10R:
Windows Registry Editor Version 5.00
; Important: The File iastor.sys has to be present in the System32\Drivers folder.
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\CriticalDeviceDatabase\pci#ven_8086&dev_3A22&cc_0106]
"Service"="iaStor"
"ClassGUID"="{4D36E96A-E325-11CE-BFC1-08002BE10318}"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor]
"Type"=dword:00000001
"Start"=dword:00000000
"Group"="SCSI miniport"
"ErrorControl"=dword:00000001
"ImagePath"=hex(2):73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,44,00,\
52,00,49,00,56,00,45,00,52,00,53,00,5c,00,69,00,61,00,53,00,74,00,6f,00,72,\
00,2e,00,73,00,79,00,73,00,00,00
"Tag"=dword:00000019
"DisplayName"="Intel AHCI Controller"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters]
"queuePriorityEnable"=dword:00000000
"BusType"=dword:00000003
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Enum]
"0"="PCI\\VEN_8086&DEV_3A22&SUBSYS_B0051458&REV_01\\3&13c0b0c5&0&FA"
"Count"=dword:00000001
"NextInstance"=dword:00000001
For ICH9R:
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\CriticalDeviceDatabase\pci#ven_8086&dev_2922&cc_0106]
"Service"="iaStor"
"ImagePath"="system32\\drivers\\iaStor.sys"
"tag"=dword:00000019
"0"="PCI\\VEN_8086&DEV_2922&SUBSYS_B0051458&REV_02\\3&13c0b0c5&0&FA"
For ICH8R:
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\CriticalDeviceDatabase\pci#ven_8086&dev_2821&cc_0106]
"Service"="iaStor"
"0"="PCI\\VEN_8086&DEV_2821&SUBSYS_B0051458&REV_02\\3&13c0b0c5&0&FA"
_____________________
Intel i7 920 [200] BCLK x 19 = 3.80 GHz @ [1.4000] CPU Voltage & [1.35000] QPI/DRAM Uncore Voltage, Batch 3836A394
3 x 1GB G.SKIL DDR3 1333 (PC3 10666) [DDR3-1691MHz] 10-10-10-24 @ 1.64 DRAM Bus Voltage
ASUS P6T Deluxe v.1 [LGA 1366 Intel X58]BIOS 1606
Thermalright Ultra-120 eXtreme 1366 RT with 120mm Scythe S-Flex F fan
ASUS EAH4850 Radeon HD 4850 1GB DDR3 @ 625 MHz GPU & 1986 MHz Memory
OCZ Agility 60GB SSD
Asus Xonar DX sound card
Antec nine hundred case, two front 120mm fans, one back 120mm Fan, one top 200mm fan
Corsair CMPSU-750TX 750W
