A) Dirty/Damaged disk = Clean disk using dishwashing liquid & hot water. Rinse and dry thoroughly. If disk is scratched/damaged then you'll need another disk.
B) Dirty/Dusty optical drive lens = Use compressed air to clean out or swap optical drives. Also check your SATA/IDE cables
C) Harddrive failing= Swap to another harddrive
D) Overclocked/Unstable system = Set defaults in bios to run stock speeds.
