After having an SSD fail on me, I decided to go and divide my 1TB Sata drive to use the Windows XP OS. There are two drives already partitioned on it and I used the smaller capacity one for my OS partition.
After the NTFS format and setup, I'm shown the "a disk read error occured, press ctrlaltdel to restart" error which disables the OS from booting. The SATA controller is enabled on BIOS and its set on IDE channel 1 slave.
I think that this may be a problem with drive letters. When I went to format the drive, the "C" drive ended up being taken by the other partition instead of where I wanted to OS to end up.
Is this the issue? If so, how do I clear up the C drive?
