- May 17, 2005
- High Desert, Calif.
Here's what happened- I'm checking a coworker's older Compaq laptop to see why the audio is not working. I notice two Windows updates notification icons sitting in the systray, so I let one start installing while I continue checking the machine. Updates finishes, asks for reboot, I say o.k. and as it reboots the the typical Windows shutdown sound can be heard; I'm thinking- hey, things are looking better. NOT. Upon reboot the machine BSODs with the following message:
Searching the net suggests that a MS update is what hosed the system, and doing a repair install or clean install is the only solution.
Any other options/alternatives?
Code:
The system dll user32.dll was relocated in memory.
The relocation occured because the DLL C:\windows\system32\ntdll.dll
occupied an address range reserved for windows system dlls. The vendor
supplying the DLL should %s %s
