the pc builder
- Jun 3, 2018
- north carolina
parallel vs series
parallel is when you have two 12v fans and a 12v power supply with all red (+) tied together and all the blacks (-) tied together. fan #1 is 12v 1A and fan #2 is 12v 1.2A in parallel they need a 12v 2.2A power supply.
series is when you take the Red wire from fan #1 is connected to red (+) of the power supply.
Black (-) wire from fan #1 is connected to red(+) wire from fan #2.
Black(-) wire from fan #2 is connected to black (-) wire from the power supply. you would need a 24v 1.2A power supply.
in series, you have to add the volts (V) 12v 1A + 12v 1.2A =24v 1.2A min (you have to cover the highest amp rating if you want all to run) (if you had a 24v 1A power supply the 12v 1.2A fan has a high chance of not working at all.
in parallel, you have to add the amps (A). 12v 1A + 12v 1.2A =12v 2.2A min
W = watts = volts x amps
you have to size the fans in accordance with the power supply. if you have 12v power supply and you have 2x12v fans than you have to wire them in parallel. if you have 2x6v fans and a 12v supply then in series is ok.
