- Nov 15, 2007
hmm this is just gonna be for advice on potential new system since i found a shop that might do price matching. they had some crazy **** like crossfire 3870s and just sold systems one for 2000 one for 1600. I was gonna write this down but what better than to leave it on a forum for criticism + i haven't done the math. I find it absolutely necessary to see what's out there now so that i don't get out of the loop to be able to distinguish deals from rips. I probably am only 20% familiar with everything that I'm listing.
I'm thinking maybe it was possible to build something close to what they did with 1300- 900 ish. Also this is an idea, retailers are suppose to sell a certain quota right so wouldn't that mean the shop would try to price match so i'd be getting everything from them?
looking at system specs like this (don't know too much about the new boards or other stuff yet) (download pdf manual ftw) (with some more research on oc potential and looking at what people have done with ram and cpu (either intel/amd) i'm thinking of putting a system together before things get expensive.
Q6600 (atm newegg 255)
Asus P5 variants one guy walked off with P5KC (atm newegg 134.99)
(this is where i think the guy is overpricing) for the processor and motherboard i asked for a quick quote he said 550-500 but isn't the board suppose to be cheap?
ddr2 seems cheap maybe add 2-4 gbs of g.skill or mushkin (of 800 before they get expensive) (atm 2gb newegg 47)
how about a zalman hsf (atm newegg 49)
DVD writer maybe something LG Pata ( i'll try to get something cheap like $40)
Harddrive 500gb WD (atm newegg 105)
1 Sapphire 3870(atm 245) or Nvida 8800 gt(atm 270) I don't care but prefer ati
Power supply and case i'm probably not the most knowledgeable about. maybe set a budget for 230.
antec 900 atx mid tower (atm 120 rebate of 40 so 80 after) well since thats a cheap enough case i'd probably spend more on a new power supply.
OCZ 700 watt (atm 135)
(time to do the math and get disappointed by the price)
(added up is 1090 with rebates deducted)
hmm the guy quoted 1300 for a non crossfire. I'm sure this is where Ocforums could provide help. I expect games to get much worse in requirements so maybe 1 card until other crazy games come out and see what they need.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115018 Q6600
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131188 ASUS P5KC
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098 G.SKILL 2GB DDR2 800
F2-6400CL5D-2GBNQ CL 5-5-5-15|1.8-2.0v
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118223 ZALMAN CNPS9500
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136117 LG GSA-H55NK 20X Super Multi drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073 WD Caviar SE16 WD5000AAKS 500GB 16MB cache
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102713 SAPPHIRE 100215L Radeon HD 3870
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130318 EVGA 512-P3-N801-AR GeForce 8800GT 512MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021 Antec Nine Hundred Black Steel ATX Mid Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341002 OCZ GameXStream OCZ700GXSSLI ATX12V 700W
this is something close to the specs the guy quoted for the $2000/1600 system:
Q6600
Asus P5KC (said he only used asus so any of the P5 variants)
either 4 or 8 gb ddr2 800
300 GB sata drive (i;m sure you can find much better)
2 DVD writers
600watt Cooler master (quoted $75 might not be a good idea)
i think i remember the ampere ratings something like 25a for 5 volt 18a for 12v
(not sure if thats enough power for 2 3870s)
Crossfire 2 3870s Sapphire maybe.
thermaltake V1? (they had one that was nearly silent so i might as well put a budget for one)
Now i'm pretty sure thats overpriced and if I drop the crossfire and find better deals on everything else it would be closer to 1300-900. but ocforum criticism please. Is this the best section for responses? dam should have posted in intel.
editing
Q6600
2 DVD writers
editing
