- Jul 3, 2001
I want to make a fan bay to stick in my 5.25 drive bay. The Idea that I have is to put togeather a fan bus that can turn down the fan volts to limit noise.
I am pondering over doing this with rheostats (full range of controll), 7v mod (not really effective for what I need, because I want to be able to switch the fans down to low voltages while the system is not loaded up, and bump them back to 12v when I game and fold), another think I was thinking about was if it is possable to make a switch that changed the voltages going to the fans (off = 7v, on = 12v) or better yet a rotating switch that had several diffrent voltage settings.
I want to get a Digi doc 5, but since it only turns the fans on and off it will not fully suit my needs, but I might buy it just for the temp probes.
If you have any good ideas or anything let me know.
