- Aug 20, 2006
- New Jersey
Im currently working on an Xbox PC.
The short of it is i am placing a mini-itx mobo inside an empty xbox case. It will include the following features (some of which i have already installed)
Front panel
-Fully functional original xbox power button (done)
-Fully functional original LEDs (Done)
-Fully functional original xbox eject button to eject dvd drive
-Controller ports 1 and 2 fully working on windows, can use xbox controller (done)
-port 3, Installed to usb ports
-port 4, swapped xbox jack for fully functional n64 jack (done)
Case Modifications
-Cut out green xbox logo, replaces with fan cage. (done)
-Installed exaust 80mm fan under fan cage. (done)
-Drill correct hole locations for motherboard.
Hardware (Ordered, shipping, not yet arrived)
This is all i am waiting for. Here is my part hardware list
-Motherboard(mini itx) http://www.newegg.com/Product/Product.asp?Item=N82E16813153077
-Hardrive(notebook) http://www.newegg.com/Product/Product.asp?Item=N82E16822148184
-Power supply http://www.newegg.com/Product/Product.asp?Item=N82E16817374002
-Processor(modest) http://www.newegg.com/Product/Product.asp?Item=N82E16819111180
Any suggestions, please tell me. I am still looking for a good way to make the eject button work. I am going to be using a notebook slimdrive.
Upon completion or request i will post picture. Thanks
Front panel
Case Modifications
