I’ve benched 4.8 with mine, it took 1.55 or 1.58v iirc. I guess I was trying to say sharing settings usually doesn’t work, and if he wants to know he will have to thrash his setup to see what it can do.
It should be ok as long as you can keep it cool
Its not something I would run 24/7 tho.. for that I generally stick with 1.275 to 1.375, wich is 4000-4300mhz for my cpu
Ha you where just referenced in LTT video.It's going to be very difficult hitting 4.7GHz on the X5690. I am a fan of the X56xx Xeons and have run a lot of them. On a good board and CPU you will most likely hit 4.4 to 4.5GHz max as a daily overclock. I know people have done more. I have tried at least 8-9 different ones including the 4 core variants and they just don't seem to clock as high as you are shooting for.
Actually took a little bit to look it up and find it, wasn't about to type out the whole link on my phone at the timelol how did you even find this thread from 2017 to post this?
**edit**
now i see this post/thread was in the video!
Just so happened to watch it 20min after going live... it was perfect timing.I came here to do the same, @deathman20 was faster =D.
