I have this Zalman CNPS7000-Cu cpu cooler
http://www.zalmanusa.com
(under orange Intel CPUs)
and this Vantec NXP-301 fan & light controller
http://www.vantecusa.com/product-peripheral.html#
(the top right product)
The Zalman cpu cooler comes with a Fanmate2, which can be plugged between the cpu cooler HSF fan and the mobo, or you can plug the cooler directly into the mobo.
I don't even know what control the mobo (currently Asus P4C800E-D) has on the spped of any cpu cooler fan, whether constantly speed control monitored by temp, or extreme temp danger throttle back protected.
The Zalman Fanmate2 does not reach the outside of the case - I drilled a hole and used 2-sided tape on top. I can set hi or low, or anything in between on the spin knob. It does not ever turn off the fan though!
What I want to know is if it possible to connect the Zalman cpu HSF cooler (fan) to use one of the (3) identical fan speed controller knobs on the Vantec fan & light controller to control min to max cpu cooler fan speed rotation. Obviously I don't want it to stop spinning.
I just don't know anything about electronics/electricity. The 3 Vantec fan dials starts at 7 o'clock and go to 5 o'clock. My 80mm Vantec Stealth fans go to work at 9 o'clock, at 20dB.
