Hey guys I just purchased my Reserator off of newegg for my system as well as all the attachments from various sites. Included in my setup was an Eheim 1250 for which I am going to remove the weak pump from the Reserator. Problem is, I can't get the dam base off of the Reserator. I've look on different sites for a solution to this problem, and have tried all methods, but the base that has the weak pump on it will not budge. If you have read a method that you think I haven't tried yet just think about what your saying. I tried using the screw driver method (which strips the holes for the holes for the coupling go), the hold/cold metal expand shrink method, hell; I even took the dam thing over to Lowes, which they gave me a very strange look on their face, and stuck the base in a vice and tried to muscle the whole reserator in the opposite direction . No go ... I don't know.
Anyone ever try leaving the pump in their and not turning it on while using a serperate pump, such as the Eheim 1250, to run your system? Or should the bad pump be on to let the flow though it when the Eheim overpowers it?
Anyway if your wondering about my current setup and situation here is a thread that explains it all when I was planning my setup months ago http://www.ocforums.com/showthread.php?p=4913286#post4913286
