- Jun 28, 2012
Oy those AIOs? I gotcha... thought you were talking custom loop .
Doesn't matter, he's still looking ~$120+ per GPU.
ah okay .. how much does that cooler go for anyway ( full kit ) I only need to cool my top card anyway . 2nd card runs 65c no problems
Which is what I am trying to get you to confirm...Try it with your cards and see if it works.I,ll check on their website thank you . does running the 1st slot at 8x make the 4th slot i have run at 8x ? if I can do that I,ll use slot 1 and 4 and i dont have to spend a penny
On my X99 motherboard (MSI) with my 5820K, when I put a card in the bottom slot it runs at X 8 and the card in the first slot runs at X 8.
If I put the cards in the first and second slot, the top card runs at X 16, and the second at X 8.
Hopefully this will be the same for your motherboard.
The difference between X 8 and X 16 is about 1% or so.
Are there 3 gpu's present?
no . only 2 . I put my 460 in the middle to act as 8x but it didn't trick the board i guess. I tried manually changing the 1st slot to 8x but there's no option to do that . I'm outta luck . my guess is you either need to change the board or the cpu.
the cpus 28 lanes dont seem to work with 3 way sli on this board for some reason. ( 3 way sli as in 8x8x8x) but only have 2 cards running.
There shouldn't be. You aren't looking to put the card in a desk drawer or anything, just free up some airspace. I think caddi daddi used one for something recently. It just seemed to me the most cost effective solution to your problem. Motherboards and liquid cooling can get expensive.
If it's mounted on its side there won't be as much stress along the plane of the card. The PCB is much more rigid when perpendicular to the pull of gravity. And if your case has a window it's a good opportunity to show off the cool bits of the card that are normally hidden. LOL
