- Apr 23, 2001
Full Article - Overclockers.com
From The Article "DVD Recorders" - Ed Stroligo - 11/16/03
NOTE This Information Is Edited :- Reading The Full Article Is Recomended
1) Do you currently own a DVD Recorder if so is it DVD-R, DVD+R or another format ?
2) Are you happy with your current DVD Recorder ?
3) Are you currently considering buying a DVD Recorder ?
4) Does the information contained in this article change your thoughts on the buying a DVD Recorder... if so why
DVD recorders have gotten cheap. Is it the right time for you to buy?
A few cautionary notes:
They're Going To Get Faster Fairly Soon
Right now, the affordable DVD recorders allow you to record DVD+R or DVD-R disks at 4X speed. That means you could record 4.7Gb of data using either format in about fifteen minutes.
The next generation of recorders coming out now allow you to record DVD+R at 8X speed (DVD-R remains at 4X). That means the time for a DVD+R recording would drop to around eight and a half minutes.
No, 8X is not twice as fast as 4X, just like a CD recorder 48X is not twice as fast as a 24X. An 8X recorder is called an 8X recorder because it will get up to 8X while recording, but it starts at a lower speed.
Pioneer announced the other day that its next recorder should be able to record both DVD+R and DVD-R media at 8X speed (the 8X DVD-R standard hasn't been quite set yet).
As 2004 progresses, 12X DVD+R recorders ought to become available. Phillips recently demonstrated a proof-of-concept 16X DVD+R recording.
By the way, a CD recorder 1X and a DVD recorder 1X are not at all the same thing. For CDs, 1X equals 150Kb/sec, while for a DVD, it equal 1.35Mb/sec. Thus, a DVD "X" is worth about 9 CD "Xs". That means an 8X DVD recorder would record DVDs at a speed equivalent to a 72X CD-ROM, so it's not like you can expect a 52X DVD recorder real soon.
Going from 4X to 8X will be the last jump that will save users an appreciable amount of time per recording. An 8X recorder could save you about six minutes over a 4X recorder, while a 12X recorder might save you more like two.
