- Oct 14, 2003
- Philadelphia
I have a watercooling setup right now i am not sure i am happy w/it my load temps are 39C w/ case temps of 25C
Can i get same results w/ air?
crimedog said:I went from a slk-800 to an alpha pal 8045 to watercooling, and I wouldn't go back for anything.
My load temps at 2.2ghz 1.7v went from 52C to 39C, and it a ton quieter. I don't even have it fully bled yet.
dalilman52 said:
well its different for every case, i mean it all depends on what u had b4 u went watercooling, the slk-800 is easily beat by the sp-97, about a 4c difference, but i dont think something like 12c would be cuased by a bad heatsink, it sounds like u just had bad airflow to begin with, and that may be the cause of such a big temp drop
i would still say get an sp-94 because amd and p4's make differnet amounts of heat and the sp-94 will beat what u have right now indefinitely
