The output of this 92x25mm fan is so anemic I'm thinking it would just be waste of power to install it as an intake in the floor of my case because it only outputs 84CFM.
If you want TRUE Power BUY a DELTA fan .... They have a 120x38 that will move "News Papers" even after going through your AIO Rad Another Factor is it sound like a jet engine
@MadMutt
I do have a Delta PFC1212DE that's been customized by HP to have an inverse PWM control. I'd consider using it if not for the inverse PWM because running it at full power is like hosting a heavy metal concert in my case.
