ABit BE6-II with "BEHXU" BIOS Upgrade & PIII-933/133 EB CPU - NOT Overclocked, but wor
Have had for some time, but ongoing "weirdness" with earlier PIII-500/100 CPU and new PIII-933/133 EB CPU (both non-overclocked). Have heard BE6 can be "unstable" when NOT overclocked. Don't know if "weirdness" is due to instability, Win98 Reg issues, or both. Never been "solid" since put together. Only marginally better as reconfigured (cards & I/O setups) thinking problems rooted in IRQ or DMA conflicts. Won't shutdown gracefully. Always locks up at Win shut down screen or blue screen. Often get Fatal Exception OE @ 0028:Cxxxxxxx in VXD APIX(01) ... or NVCORE(01) at boot or shutdown - always need to do "hard off", then Safe Mode start, reset all video settings, then can get reboot. Shutdowns NEVER complete. Usually power down at locked screen, boots up next time, but often get sys lockups that forces restart.
A "veteran" out there who enjoys challenge and sharing expertise? Would appreciate help me get running as "rock solid" as those read about in forums. Like to learn some OC tricks too! My setup is:
ABit BE6-II w/ BEHXU BIOS (QJ, SH & UH before)
SDRAM = 384MB (3-Infineon 128's)
AGP Slot - Leadtek GeForce 2mx (1280x1024 True Color)
Slot 1 - Empty
Slot 2 - Empty
Slot 3 - Adaptec 2903B SCSI Card (for HP CD Writer 9200i, ZIP-100, CanoScan FB1200S)
Slot 4 - Kingston KNE110TX PCI Fast Ethernet Adapter (for Speedstream 5260 ADSL LAN Modem)
Slot 5 - Turtle Beach Montego II Sound Card
Slot 6 - ISA LPT2 ECP Port (EPSON Stylus Color 800)
(Also wanted to install ATI-TV Wonder ... but won't work on repeated reboots with any card slot combo using PCI steering - so dumped.)
A: Drive - Standard 1.44MB Floppy
B: Drive - LS120 (Mode 2; IDE 1 Slave)
C: Drive - Fujitsu 3.2GB (DMA-33; IDE 0 Master) - for Win98SE Op Sys & basic
D: Drive - Maxtor 20 GB (DMA-33; IDE 0 Slave) - for Progs & Data
E: Drive - Iomega ZIP (SCSI ID#5 - Card Ext connection; daisychain to scanner)
F: Drive - HP CD Writer Plus 9200i (SCSI ID#6 w/Active Term- Card Int. connection/cable)
G: Drive - AOpen DVD-9632 (DMA-33; IDE 1 Master)
H: Drive - USB CompactFlash Reader
Scanner - CanoScan FB1200S (SCSI ID#2 - Terminated)
Com 1: Disabled
Com 2: USR 56k V.90 Fax/Modem Ext
LPT 1: NEC SuperScript 1260 Printer (EPP)
LPT 2: Epson Stylus Color 800 (ECP)
SoftMenu III is set for:
CPU OperFreq=933/133
Video BIOS Shadow = Disabled
PnP OS=Yes
RAS-to-CAS Delay = 3
RAS Precharge = 3
CAS Latency = 2
Precharge = Disabled
System & Video BIOS Cacheable = both Disabled
AGP Aperature = 4MB
DMA-66 IDE Controller = Disabled (used before; dumped to avoid conflicts)
Onboard Com1 = Disabled
On past ocassions, during bootup, hardware "re-recognized" hardware & reinstalled drivers, then locks up. At one time, Reg had 3-5 entries for each device. Fatal OE errors, bad shutdowns, system locks are frequent.
I'd appreciate some assistance ... learning something new ... and getting to know some new techies.
Hope to hear back from you,
powerjak
Slot 1 - Empty
Slot 2 - Empty
Com 1: Disabled
PnP OS=Yes
RAS Precharge = 3
CAS Latency = 2
AGP Aperature = 4MB
powerjak
