thats all my aerogate does.
First of all when u guys put a rheostat does it reduce the fans max. performance? I think mine is. like my fan only reaches 5400rpm when the specs of my tornado says 6000rpm.
Second of all. When i lower my fan speed to the lowest, which is bout 3000rpm, my fan makes this rattle noise. any idea.
The last thing. the aerogate is meant to make a beeping noise if the fans die out. But when I turn off my pc it makes the irritating beep noise cos it thinks the fans are dead but the pc is off. This really defeats the purpose of the automatic shutdown. I have to be there until the pc totally shutdown and the beeps start and then i gota disable the beep.
beep...beep beep.. beep beep. beep..... beepppppppp
